Fuel getting in the lines may be from mounting it so the lines don't run all down hill from the compensator to the float bowl vents. With them running down hill the fuel drains back into the carbs automatically. I have never had that happen with any of mine in 5 or 6 years. If your sled didn't have altitude/temp compensation the ATACC is about the only option. I sure hate to leave any HP on the table and jet lean enough to run clean at 10,000 ft in the afternoon at the 30 degrees in the sun and then worry about squeaking it early in the morning down at 7500 ft at 5 degrees.
Mounting it in my mod long track XP TNT was quite a challenge to get the lines running downhill.
Good Luck
Here is my latest gauge for tuning I played test mule for, it was originally made for twin turbo automotive drag racing, etc.. It has Left and Right EGT plus Pipe Belly EGT, TPS, Air Fuel Ratio, RPM, MPH, Coolant Temp, Air Intake Temp, and it Data Logs. Can add jackshaft Rpm or even 3 axis accelerometer. The screen is touch screen, any reading just touch and a list of all sensors comes up and you can change to any one of them. Also has multiple gauge faces (layout, analog look or bar tach) to choose from.
The two things that are really awesome with this gauge is the TPS, just glance down and see at 32% throttle opening what your EGT's are and the Belly Pipe temp gives you a clue as to where your HP peak is if you Dyno it and match the Belly Temp on the dyno. In other words lets say at 1000 degees pipe temp on the dyno HP peaks at 8000 and at 1100 degrees it goes to 8150 etc. Now you can tell pretty near exactly what happens in a climb to your HP at what R's and where to try and optimize clutching. DynoTechResearch.com has been getting into this quite a bit lately.
