hi guys been reading alot about the fix kit. made up my mine and ordered it yesterday after talking to shawn at pms. this after I took exhaust valves out for a cleaning and check the pistons and found scoring deep enough to catch an oring pick on. ok ok my question to all of you with the kit is what flash are you running in the ecm. also my sled has 12.5 power addiction head, aaen single pipe, hps can, pcV with autotune. also ordered pink exhaust springs to try. sled is running 70 gram polaris weights and stock spring for 0 to 6000ft and 64 gram polaris weights and stock spring for 6000 to 10000ft.
let me know what you guys think of this setup and what flash is good to use.
Sled is a 2010 polaris assault 800 with 146 comp track with a tooth off the top gear.
Thanks
Thanks
