Just wondering how your sleds are working now with your changes? anyone find big improvments/get em totally dialed in now?Or still having issues?
On my 08 D-8 163 with slp single, 19/42 gears,VF-3 reeds,slp intake kit and vents, I have tried a few new things(new primary spring and 2 helix shims added for this ride) and as of 1- 80 mile ride this weekend this is what my setup is:...
Carls 62/42/.46 helix
stock secondary spring(black/purple)
3-delrin washers
2-slp .70 thick spring shims(reducing initial angle length from .46 to .36)
slp green/pink spring(160/340)
slp mtx 68 gram weights with 2 grams tip and 1 gram in the belly
sled engages at 4200 rpm max rpm 8400 at 4000 ft elevation(with slp single pipe) So far this is the hardest pulling setup I have found of all the stuff I have tried.best track speed on a good steep climb in powder snow was 51 mph on average it pulls 44- 46 mph..( a few weeks ago in really good champayne powder this setup minus the shims and with slp blue pink primary spring pulled a best track speed of 57 mph at 8450(repeated climbs yeiled same results)..am very happy with this setup.is very responsive and great back shift and almost zero belt heat(although I did pull strings on my belt this weekend but it had over 1100 miles on it so will monitor new belt to insure there is not a problem..
3-delrin washers
