SteepNdeep, oil temps very important to longevity. i was very curious about oil temps given the case exposure to heat sucking environment. As kind of expected, oil temps are frequently lower than optimum. The only time oil temps get above 200 is when on trail. The highest I've seen is 250. That is with most of the case covered. With the oil temp info I can make changes as I ride to optimize oil temps and if oil temps stay up for most of a ride I don't worry about changing oil as often.
Regarding your 230 temps. Do you have a fan or heated bars. I have both and I think they both help when the heat load increases.
I'm happy with the Evans. Have not used engine ice. Temps might run a bit warmer with Evans but won't boil over. My fan kicks on at 200 so that helps reduce the 230 temps
