Michealmolach, I would suggest engine coolant temps around 200f. A 195 degree thermostat is good but you will need rad covers to get consistant temps. Boiling over can be an issue with traditional coolant on long climbs slow trees. I've had great success with the Evans waterless coolant as it does not boil over so no mysterious coolant loss. There are several good post here on the coolant temp issue. Hopefully, the search function works with this new setup.
The closer to 200f the better. Engine longevity, fuel economy, oil life and film strength benefit from 200 degree temps. Ideally your engine oil would be above 200. I have an oil temp and coolant temp gauges on one of my bikes. In any kind of snow with mostly covered engine oil temps run under 200. On long trail ride with little snow I have seen 250 on oil.
Regarding max temp, 220 won't hurt the engine unless it boils (it will) and then develops hot spots due to coolant loss. Again, some good discussion on prior posts. Good luck.
