Push M8 Turbo kit
M
mightymg
Selling my M8 push turbo G kit. This kit is a great kit that is one of the best cleanest kits around.. I bought it at the end of the winter for my m8, but I decided im changing machines.
The M8 it came off of had it all dialed in control box wise. This is a pump gas kit, but the previous owner dialed it on to run a 50/50 mix.
Over all it is in great shape, and it comes with all gauges needed for engine monitoring, and for tuning. this kit also has the third injector assy in the charge tube.
$1600, plus stock bits. exhaust,throttle body,primary, and gas tank( I will include mine which already has the high flow pump installed no sense in swapping internals)
http://www.pushturbo.com/M-SERIES.html
Call or text.
8013909757
Located in Mountain Green Utah
Thanks..
Lane
what year of m8 did it come off of..??,,how was this turbo on the other sled for spooling up ok...was the lag miminal..??
I have never ran this turbo kit, I never got around to installing it. it has a smaller turbo on it , so it spools very quick.
Push turbo
I saw this turbo kit on ksl the other day. The add is no longer there but I thought it said you were running it on pump gas and had put on 600 miles on your sled.
Yes it was the same ad, kit says its for pump gas, but the previous owner was runnign a 50/50 mix, and that how it said it was tuned the best and ran the best. I removed it from ksl yesterday because i thought I had it sold, but it was a tire kicker...
Like i said in this ad and the one on ksl I never installed it.
The pictures above are the ones i got from the previous owners sled that i bought it from.
as far as the exhaust goes, the previous owner had changed it to a bottom drop as he thought he was having issues with snow plugging the front exit.
:usa2:
He was having deotonation problems that he couldnt figure out, so he went to a 50/50 mix and it solved everything.
Below are the numbers from the previous owner.
Numbers in the box as follows- 7000ft- 11000ft in WY
green 1
yellow 1
red 1
Green/blue 5
Yellow/blue 5
Red/blue 8
Fuel PSI- 32
Gave 1220egt on a long pull and crazy power
