push 180 kit
turbo
so does 91 octane alow me to run 8 lbs at 1500 ft or to i need a little torco acelerator or the like to bring it up a bit?
I run the push kit at 9lbs from 4,000-7000ft and put some octane boost in, it's cheap insurance from detonation. Being that low I'd run gauges and put some octane boost in. I just sent my parts off for the upgrade and can't wait to run more boost this year.
yes its a peace of mind knowing you have good fuel tossing in a little boost. you never know when you will get a rotten batch of fuel.
has anyone played with the fuel controller? all my settings are on one.
only difference i know is push doesnt have a oil return pump
There are quite a few differences between the two. The biggest one I think is the turbos. The Mitsubishi turbo used on the MPI is not a performance oriented one. The push unit is purpose built not an off the shelf product and it spools really fast
i believe so. the MPI has a switch so you can change from low altitude to high riding. the push kit has a fuel controller which i havent experiment yet.
hope someone chimes in with some numbers on the controller and what octane they are using. stock compression so one has to be careful
I'm guessing your settings are not all at one. Here are the base settings given to me by Ken at Push.
M-1=2to3
M-2=2
M-3=2
M-4=6
M-5=4
M-6=4.5
These are baseline settings for 8to9psi 4000 to 7000ft
If it pulls hard, holds 8800rpm +/- 100, and does'nt pop pop,you should be good. A boost guage,AFR,and temp are nice to have. I like my KOSOx2.
That switch doest come with stock though.. i have to pull the seat and dog house off to adjust the waste gate. i guess i was just curious to see if the MPI could make that kind of HP like the push. Does any of the other 180 kits make 200hp?
The mpi Kit will make the will make 200 just the same as the push 8 to 9 psi of boost is the same no matter the kit. Just as long as you have good fuel and good air fuel numbers.
