purelogic tunning M1000 with SLP set up
Hey guys have a SLP Pipe set up and a pure logic box for my 2009 M1000. Anyways does anyone have settings for this? Also once its set if I go from Cooke City to ND do i have to re adjust it?
Wow! It's like having two seperate posts in one..........Maybe you should start a new thread with your issue Powdercrav?
Vmax, really all you need to run that pipe safe on the '09 is 8-10% more fuel right in the middle like 5500-5800 and 14-18% more fuel from 7250-7750 or so. Other than that, it is just tweaking to perfection in all other areas. As far as altitude goes, it should adjust for you through the ecu. Good luck!
Aaron
