pure logic
so just traded the turbo yami for a turbo m8.... it has the pure logic box on it and im just trying to make sure i understand how to use it. any suggestions would be greatly appreciated
Before you start adjusting you box because your sled is not running right on the top end, CHECK THE PLUGS FIRST...you should not have to adjust the fuel too much on a set up sled.
Your best bet is to call Travis. I just switched form a boondocker box to the PL box. He was a big help in explaining how it works. I would start with new plugs for sure. I put BR10EIX in and they seem to work well.
I am new with this box but here is what I know about it so far. The green light is like the pilot jet, the yellow is like changing the needle, and the red in like the main jet. They all build apon the previous value. So yellow adds to the green and red adds ontop of both. The green blue is boost up to 8 lbs and yellow blue is from 8 lbs+. you want your AF around 14.5 cruising off boost and no higher that 12.5 on boost at WOT.
