since you asked about the waste gate sticking what is it doing? what lb wastegate spring is in it and how many lbs of boost is it making? Why do you think the wastegate may be sticking? if you do not have any kind of boost controller you will run a air line from any where between the turbo and the throttle bodies to the bottom of the waste gate. The top of the wastegate you can hook a line up to and just vent it to atmosphere. if you have any form of boost control you will tee into the line to the bottom of the wastegate, to you boost controller, and then to the top of the gate. Boost controller adds extra presure to the top of the wastegate to hold it shut and build more boost. 7lb spring in the wastegate and 3lbs of air presure on top of the wastegate means you will be runing 10lbs of boost presure. If the wastegate sticks it will not open and will build alot more boost then you are supposed to be runing. I have never seen one stick open, but if it did it would bleed off all the exhaust presure and you would not build the desired boost presure.
