I wonder how many guys saying you don't need a puller have actually taken the out half of a TRA7 off......the older TRA's were splined and slid right off relatively easy, on the '07 and newer the 2 halves are a taper fit just like it is to the crank. I would not attempt this without a puller....I'm sure it CAN be done, but why risk a $200 part when a puller is $35. The TRA in the link above is the older splined TRA, those can be pulled apart on the hill...the '07 is different!! JMHO-![]()
primary
put a wratchet strap on the footwell and in one of the holes on the primary, to keep it from spinning when you turn the bolt
once loose, it will just come off (just pull on the primary or tap it w a rubber mallet)
HERE is a link to what I am talking about
really is super easy
