Picked up this ride summer of 2010 with just under 400 miles on it. So, being in it's third season I didn't expect the issues I am having with the PTO plate mounting. In AC's infinite wisdom, they decided to use nutserts instead of studs (guess they figured it out for later years). The darn nutserts started self destructing, playing havoc with clutching until I figured out what the heck was going on. So, being mid/late season, the real fix would mean more work than I have time for. So, I just "bucked" them by running a bolt through them and running a nut onto the bolt from the other side and "squishing" the nutsert to make it bite the bulkhead again. The hope is that they will hold for rest of the season. If anyone has tried this before, please share...
On to the snubber. Have been toying this idea around for a while and am thinking about pulling the trigger. Using an old SLP mag side snubber from one of my old Polaris sleds, hope this will do the trick. (the stock PTO snubber on older Polaris sleds is basically the same thing).
There is two threaded bosses in the upper crank case half on the back side of the motor. Would work perfect for a torque stop snubber bracket. (don't know if the later model motors have these). The only issue with doing this is that I feel the cooler (which the rubber snubber will be contacting under load) might be on the thin side and require a fish plate welded on to spread out the load. Let me know if anyone has gone down this road before....
Why do this? Well, one of the things that Polaris had going well for them in the motor mounting department IMO was using this type of torque stop. Use in front and behind the PTO side of the motor in-line with the crank worked very well on all my mods over the years. Why not give it a try here?
