PSI III Genesis 890 Engine/Carbs/Pipes
About 150 miles on it. RUNS GREAT! Like new setup. pistons and cylinder inspected and can still see the cross hatch pattern in the cylinders. Pistons look like new. Around 180 hp. Still in sled so you can see it run and drive IF you can hang on! This is the 700 bottom end with the 890 cc upgrade kit from PSI. Upgrade is $3995.00 alone. See the psi site for details. It is the big block non ves motor. Comes with airbox/carbs/cdi/clutch/twin PSI pipes. It runs great with the single pipe we put on it - you are responsible for tuning with the twin pipes. Has SLP water temp gauge that comes with it - nice feature. Dial a dome heads -has 125 lbs compression even. Boost bottle. runs on pump gas. nice mod motor. email is probably best to get a hold of me rgextreme1998 at gmail dot com, i'm not on here too much. I can ship it as well for about 150, professionally packaged.
$2000.00/bo.
It is in shell lake WI right now in a 99 xc 700 gen 2 sled. Can be seen there or possibly in Stillwater/Twin Cities. have some videos i can email you to get a sense of the beast and of course pictures.
