psi genesis 1000
snowhippy
does any one know the fuel raito for the psi 1000 .... how many lbs to run pump gas ,, lbs to run 50/50 mix .. lbs on race fuel . would be greatly appreciated .....
You need to cc the head, know the cylinder size, 1000 twin would be 500 and do the math to get you compression ratio. That will tell you what fuel to run. Cranking compression and compression ratio are too completely different things. Good luck.
