1999 Arctic Cat ZR440 SnoPro Chassis with PSI 1500cc triple. PSI cylinders with RAVE valves, Dail A Dome heads. Polaris watercraft bottom end--case reed. PSI carbs and exhaust. Best of everything PSI had to offer! Extremely low run time, probably less than 50-100 miles. Stage Six six tower clutch. Additional running board cooling added. $8900/offer.
Will sell motor seperately.
Arctic Cat Wildcat chassis with PSI 1350cc triple. PSI cylincers with RAVE valves. Dial A Dome heads. Decker Racing bottom end--made up of 2 700 Wildcaat cases mated into a 3 cylinder--case reed, PSI carbs and exhaust. Once again, best of everything PSI had to offer! Extremely low run time, probably less than 50-100 miles. New Micro Belmont four tower clutch. Additional Cooling added. $6900/offer. Willing to sell motor seperately.
For you snowmobile enthusiasts who have attended West Yellowstone Snowmobile Expo's. These sleds took top speeds records every year they attended. Never trail rode--radar run use only! They both started as new chassis', never riden, and then had PSI motors installed. There were no expenses spared! If you want a turn key sled or just a motor for a project, here is your chance. Base motors alone (no carbs, exhaust, etc..) were $15,000.
There are 3 different dome insert sets for each motor--39cc, 42cc & 46cc available. Prices above reflect one set only being included. Many new spare parts available--cylinders, pistons, carb parts, etc.--PLEASE DO NOT CALL WANTING TO BUY PIECES.
If you have interest, please call: (320) 382-6128. No Forum private messages will be responded to. If you chose to email: info@tracksusa.com Thank you.
