Saw this over on johndee.com,
Is this guy onto something or smoking? If it has been done, is there a reason Nos is used and not propane? I know nothing about how Nos, etc works, just that I want it on my sled someday.
Ok guys, you're going to think I'm crazy for trying this, but believe it or not, it WORKS!
I mounted a 1 lb bottle of propane on a fire extinguisher bracket to my belt guard, and strapped it down with a pair of velcro straps.
I modified a torch valve and plumbed it to a tee fitting for a guage, and then out to a solenoid valve.The wiring to activate the solenoid comes off the power feed for the accessories on the Rh bulkhead, and goes to a spring loaded push button switch on the left handlebar.
When activated at idle or midrange, the engine rpm will decrease or die from the extra fuel , but at WOT, awesome power!
The principle of propane injection is similar to that of nitrous, albeit that nitrous oxide is an oxidizer, and requires additional fuel to keep the engine from burning down.
Propane however, is very high octane fuel (110+)and is introduced into the air stream (a modest amount )at the point that the carburetor is reaching its volumetric efficency(WOT)
Propane boils at -41 degrees, so as it is injected into the air stream, it cools the incoming charge to around zero degrees based on an ambient temperature of 40 degrees. I am still experimenting with finding the optimum air/fuel ratio mix,orifice sizes, etc.
Now that I see that it can work, I will next change my cylinder head over to a billet type HotSeat dome setup for dependability.
In the next few days, I will have some pix available if anyone wants to see how to DIY to your own sleds.
Another thing I forgot to mention, a cylinder of propane is only $3,
and will last considerably longer than any nitrous bottle would, as refelected in the fact that a perfect air/fuel ratio of 14.7:1 requires the use of 14.7 units of nitrous to 1 unit of fuel.
Propane requires 1 unit fuel to 14.7 units of air, get the picture?
(i.e., will last for hours if used in moderation)
If anyone has any input/questions, I am open to discussion, so feel free to contact me................................(ooo)\>_
