problems w/ Attack 20 on DD w/ mech reverse??
White Rad
Found this old thread asking about how to cut down an A20 to fit a DD w/ mechanical reverse.
http://www.snowestonline.com/forum/showthread.php?t=164173
So what is the deal, did people have problems with the rubber nubs and clips on the inside of the track on left side hitting the DD case w/ mechanical reverse? My sled came with this setup and havn't ridden it enough to know if its an issue. looked up under there last night and it look close in a few spots but i can't see that its hitting anywhere. snow if finally coming back our way though so shes getting a goood test ride soon!!!!
I did cut it down as there is not much clearance. Very easy to do, just pull the track off and take a hand grinder to the side by the drive. I am running mine in hillclimb. I don't think you need to do both side, just for the drive side. I just put 50 miles on last weekend with no problem.
did you do the little rubber nub and the end part of the metal clip?? if i'm going to this may as well port it too while its off. hows that thing feel in hillclimb? still can't decide if i want to flip mine...
They don't call it the HeartAttack 20 for nothing . . . I would toss it in the garbage and buy a PowerClaw. Flipping it around causes a major decrease in braking ability.
