Problems starting 99 RMK 600
T
tdr24
New member
My RMK 600 takes forever to start! Once i got it started it didnt miss a beat all day. Then i went and took it on a small ride the next day and still took forever to start ran fine until i pulled up to my buddies and it just quit. I couldnt get it started and still havent been able to. If anyone has any advice i would appreciate it!:face-icon-small-coo
We could use a little more info, Spark?, fuel?, compression, did you try new plugs? It kinda sounds like a fuel pump that got weak and quit but that is a big guess without a little more info.
99 600
Check the compression. When they get borderline low, they will do that.
99 600s have a compression relief hole in the cylinders so you won't see huge numbers. I live at 3400 feet and get around 90 on two different gauges.
It has Spark and have put new plugs in it. How should i tell if the fuel pump is weak? But i was thinking maybe it Needs a new set of Rings but i will check the compression and see what it is Thanks!
almost ruals out any electrical, had a 700 that acted a little like that and it was a short in a wire comeing up for the belly pan to the cdi box.
Got it running finally there was a lose wire running into the CDI box thanks for everybodys help its really appreciated:)
