Problem M8 help
09 M8 Turbo
OVS Aurocharger 66mm
Pure Logic Box
A/F ratio gauge
Problem #1:
Pure Logic box center line appears to have a crack. Is there wires inside this line or is this a boost or vacum line?
If this is a boost line can I open the Pure Logic box and shorten the line, How is this done?
Problem #2:
Pure Logic keeps resetting going down the trail, its not like hitting a bump but more like when you apply the trottle. No consistancy. Is this related to #1
Problem #3
No control on Pure Logic box with the A/F. It will go up and down but at green on the low side (moving slowly) A/F read 15.5 and its set at 5 green. Its never been this high usually 1-2. As I speed up and the green light is almost ready to switch to Orange the A/F then goes to 13.1 (it appears to be working correctly, if I justed the box to 1-2 then I would be at 14.2 which is correct.
Is this related to problem #1 or do I have a plugged injector?
Problem #4
Plugs un-even color.
Left plug is mag side, Right side PTO side
center line(hose) is for boost reference for box, this is needed for fuel regulation, there is a short nipple on box, remove cracked hose, repair, reinstall hose on nipple. check all hoses for damage. good luck!
Every time I have had my PL boxes reset like this it has been an electrical issue. Either a loose ground or you have a wire that has rubbed through and is grounding out on something. Check all wires, Check all Grounds, Check Injector plugs, Water in a connection. Etc......
A crack in a boost line is just adding to the problem. This wont make the box reset itself.
