Pro RMK Vent Kits
Looking to put vent kits on my sled. Have a sticker kit so I don't want anything on the side panels. What do you think about the Holz console vent kit or other console vent kits
I bought the Holz console vent kit on clearance for the Pro, looks decent, have not installed it yet, not sure how easy that will be or if the instructions are good or if you just have to wing it...
Go for mtntk blowe hole and you are good to go :face-icon-small-coo
That was going to be my suggestion, But they have changed the design and they vent out the side panel....Which he didnt want.
I think they work awesome, had one On my 16 and will get another for my 17. Best venting option on the market...Plus its great for quickly thawing out frozen goggles. Eric
I recommend this also.
The MTNTK Performance Blow Hole for the Polaris Axys is mounted on the side panel of the sled, however, the Blow Hole for the Polaris Pro Model is mounted on both sides of the middle console of the sled. Both work EXTREMELY well and move unwanted heat and debris from your clutches without overtaxing your system. With its low amp draw, water resistant DC Fan and durable aluminum design, the MTNTK Blow Hole keeps your clutches and entire under hood area cleaner then a just normal vent. By using an Active Venting system, your machine collects less belt dust = longer life for both your belt and clutches. Don't forget: Every MTNTK Performance Blow Hole is a TRUE Plug and Play Design, with absolutely no splicing, cutting, or wiring. Visit https://mtntkperformance.com/ for more information!
