D
diesel5
New member
My 2011 800 pro started running bad last March, just got off the phone with my dealer. Polaris thinks they figured out the problem. If you are running non-ethanol fuel you must run the correct resistor, same if you are running ethanol fuel check your resistor. The resistors change the mixture by 8%, change your plugs and put in the correct resistor and your sled should run better.
They put all this new on mine before finding this problem.
Fuel filter and pump
injectors
computer
I switched mine out on Sunday and it definitely ran better.
injectors
computer
