Factory 2011/12 Pro Drivers or drivers w/shaft.... or 2011-2016 Std Pro Rmk drivers or drivers w/shaft will also work.
I don't think the Wahl drivers will work on the 2.6" poo track...no drive nubs on the outside of the hyfax with the 2.6".
The Avid "PC style" drivers will work.... and the involute with toothed center from Avid as well (for those timid of trimming rails)
I recommend 7 tooth drivers with that track... will give you some much needed clearance... It is a single ply track, All the factory AXYS sleds are also running the 7 tooth drivers... and they work well ! Heck, I've seen benefits for a buddies sled when he ran 7 tooth drivers with the 2.4"-lug, series 5.1 stock pow track.
The chaincase mod takes about 20 min or less for a good welder/fab. IMO, the added clearance benefits outweigh this minor inconvenience.
With 7-tooth, you will get the added benefit of a bit lower 'gearing' from the smaller drivers.
If you want a bolt on option with the 7 tooth, and no trimming of rails... you can use the driveshaft from a 2016 AXYS sled that uses the chain-drive (Pro w/3"-lug, SKS or Assault)... you will still need to mod the driveshaft.
Good thread from TRS... points to clearance benefits in the ProRide chassis with deep lug tracks.
http://www.snowest.com/forum/showthread.php?t=374678
For the drivers...
You can go with the Center drive 7-tooth from Avid
CLICK HERE
OR, IMO a better way to go...The "power claw" style Combo drivers... trim the rails and run an anti stab kit.
CLICK HERE
