Yes, the Arctic Cat 048 belts "work".
No, the dimensions are not the same from the Arctic Cat 048 belt and the Polaris 115 belt... both in length and side angles.
Yes, I believe that dimensions of a belt play a critical role in the performance of the clutch and how they shift out towards max as well as the backshift feedback/response.
I've had many friends that get a season of HARD turbo use out of a 115 belt.. and with the cost of sledding in general, a spare 115 belt each season is not that big of a deal.
If you are shredding 115 belts, which can withstand an nuclear attack, you have some other problems with your sled and clutches that would be seriously impairing the performance of your sled in the first place!
Wash/scrub your belt every 3 or so rides and keep the clutches blown out and clean... change your springs regularly.
... if you want strong, consistent & reliable performance from your sled.
Sleds are about as close to piece of racing equipment as a consumer can buy with a warranty... they require regular maintenance... much more than your Honda civic or diesel truck... that is a fact of life.
The 3211080 belt is not a bolt on and go belt either as it is a bit narrower and needs the spider re-shimmed for proper clearance (re-shimming requires special tools and experience with shimming)
My 2 cents.
My 2 cents.
