J
Jaynelson
- Front track shock tightened with roughly an inch of threads showing (as GMAN said). They tend to like the front track shock a good bit stiffer than they come from the factory. This adjustment makes a big difference on Pros.
- Leave the swaybar in with the stock shocks/springs. Although if you've got the Assault shocks and the springs are stiffer....hmmm not sure there.
- Don't go hog wild with the front ski shock tensions....I would leave them as loose as feels comfortable.
- Rear track shock depends a lot on weight.....I went by the chart in the owners manual IIRC and worked well. As a really generic answer.....I would tighten it until it bottoms very rarely and you should be good. This adjustment also makes a big difference on pros.
- Bars.....the pro tapers are good for me at 6'2"....so they may be too high for shorter dudes.
