I could use some help with my brothers sled, a new to him 2012 Pro RMK 800 155 with an intercooled Boondocker turbo running av gas that got towed to the trailer yesterday. We had a good morning, that sled was ripping hard all morning. When we came back out from a late lunch and started up the sleds that one was only running on one cylinder so we changed out plugs with new ones but it didn't help. I towed the sled back to the trailer and we started working on it today.
I did a compression test to start the diagnosis, both cylinders are 125-130 and within 3-5 lbs of each other. My first thought was that it might be an ignition coil, one of the other sleds on the trailer is a 2011 Pro RMK 800 155 that was running fine all day so we swapped coils with that, that didn't help the turbo sled still only runs on one cylinder. It doesn't clean up at higher rpms, just keeps running like crap and one side EGT stays at low when the good sides 350-400 degrees on Koso gauge. Using an IR temp gun the mag side of the cylinder head stays way cooler too so I think that's the problem cylinder. Pulled the plug and checked for spark by grounding the plug on a cylinder head bolt, both plug wires have very similar looking spark.
The sled will start and idle like crap with both plug wires connected, removing the mag side plug wire doesn't change the idle at all, still runs like crap. If I remove the clutch side plug wire the sled won't start or stay running at all, just dies right away. I put some starting fluid down the mag side spark plug hole and tried starting the sled with the clutch side plug wire disconnected, it doesn't even want to start.
I feel like I've checked for spark and fuel but EFI sleds are new to me and this is the first turbo sled I've ever touched so that's definitely new to me. Any pointers someone might have? Thanks in advance, I'm not sure if this should be in the turbo section or not but it doesn't seem like it since it doesn't seem like a turbo related issue to me
