Hey tlk I bought a 2003 tra for my hawk. It is suppose to be for a 600 rev mxz. Not sure what I will need for weights. Baseline, can I copy the rev specs and fine tune from there.
I ride at 1500' at home and when I go west I ride 6700' to 9000' Island Park
I have little experience with tra but I can manage.
If I were you bmiller Id start off with the '02 503F Summit setup. It's got the TRA primary pretty surprisingly ! Now I don't know what TRA you have (1, 2 or 3), the ramps may not be interchangeable from 1&2 to 3, working principles are pretty much the same though. According to the doo online parts catalog the setup goes as follow:
Yellow/Yellow Spring (100-230lbs)
296 ramps
Pins weight - Can't tell, there's only the part number, no specs.
I read lots and lots on the Doo forum about clutching and so far there's just half of a handful of guys really knowing this territory (unfortunately there's soooooo much BS on these threads...) and the most useful info I found was on Dymano Joe's website :
http://www.mxzx-revzone.com/ Go to the Clutching IQ section, that's an unbelievable source of info. Pretty much all the clutching problems are stated there and a solution is proposed
There's so much useful & interesting information, read all that and try to understand what he means, everything makes sense.
Not that being said, I think the yellow/yellow spring might not be enough force. That low force spring will allow the engagement to be really low in RPM I think and we may suppose that Doo put that spring in because a 503F Summit is more a girl or a kid's sled than anything else ! You may go with a little more force for I think. Read the website here again there's a section on springs.
Get yourself a kit of adjustable pins weight, you will need it for that much height elevation. These pin weight are directly related to RPM, want higher RPM, take some weight off. Overrevving - Add some weight. If you're an experienced snowmobiler you'll notice you won't be able to carry as much weight at 9000 ft than 1500 !
Clickers are kind of a tricky thing cause you can correct you RPM with them. They change the angle of the ramp. But what Dynamo Joe says is that you should start by choosing the best clicker # (the one that will give you the most straight shift (read website for definitions...), THEN adjust RPM with the pin weight. Of course if you're lacking 300 rpm and don't have the tools, click her down but the way to do it would be clicker first then weight second.
Secondary is another thing. It is a torque sensitive device. If you have the stock 50-44 Helix, I think you should go down on angle just a bit if you ride mountains & powder. 50-44 is awesome for sea level trail though, that's what I had on my 503. That less agressive Helix teamed up with a bit stiffer spring will allow quicker backshift when you "load" the motor when hitting a softer/deeper spot of snow. That setup will transfer less of the load to the primary and you'll be able to hold you RPM.
Hey Damn gotta stop ! Everything's on Dynamo Joe's website ! Good luck !
Ramp profiles can be found in the Doo Racebook and Spring forces can be found below that post !
