Primary Weight Bushings
boondocker97
I just had my 2018 roller primary apart this past weekend adjusting my MDS weights, and I noticed the bushings are already worn. I put the clutch on my sled around the 1900 mile mark and this was at 2300 so 400-500 miles at most on the setup. Two of the weights had a little side-side play at the tips, but the third one has about twice as much play. Bushing in that weight is visibly oval shaped, and the weight is starting to wear into the thrust washers on either side of it. I flipped the side plates over to put a new surface against the weight for the weekend but I'm looking for replacement bushings and a installation driver now. I searched Country Cat and didn't find anything. Anyone else find any good replacements?
Just following up...Steve @ MDS fixed me up with a set of bushings for $15 shipped for all three and sold me a driver he had in the shop to replace them so I didn't have to track one down myself! He said it's definitely not the norm to wear them out as quick as I did so I'll be checking the clutch over thoroughly when I change them out. Speedwerx does have them, but they are $16 for each bushing.
