I run about 7lb boost and ride about 10k +- and have my primary loaded up with 72.3 grams. Runs perfect 8200WOT. Now lets just say one day I wanted to put some race fuel in and run 10 lb boost, how bad would it over-rev. I have the rooster adjustable weights but is there a "rule" for pounds of boost / grams of primary weight. I have found over the years that 1 gram is equal to about 150 RPM's in most cases. Also if I where to add the extra boost and was going to add X amount of weight is it better to add that weight closer to the pivot point of the weight or out on the toe? Yhanks in advance.
