Primary clutch parts
Back to the dilemma of replacement parts for a primary clutch. Does anyone know if cat parts for an 06 clutch will work on an 07? I need to replace the movable sheave and hate to buy a new clutch. It looks like it may work, but the part numbers are different.
i'm sending mine to racin station, 07 M8, they rebuild and balance them for $150, they could probably set you up with parts.
As long as both of them are three arm clutchs they should work.
But I would personally suggest getting a new clutch. I have found that by reusing the spider and the balance issues that you will have, you are better off sending it to someone like racingstation and getting it done or getting an uncalibrated clutch and being done with it.
I have been down this road before. It never really works out that well and in the end I am into it about the same as purchasing a new one.
Thunder
The deal is I sent the clutch to slp to balance and install weights and they found the problem. If I could buy just the movable sheave, I could be up and running for $150 bucks. I am almost sure the parts are interchangable between 06 and 07, but would be nice to know for sure before purchase.
I am assuming this is a M6 -M7 model ??? The 2007 is different - they changed the size of the primary sheaves to be (smaller) because they made the second sheaves (10.4) larger. It won"t work - you would have two different sized sheaves - Sorry
Bill
