Rick!,
I see where you are coming from for sure.
It all depends on how much air you think is coming IN the openings on a mountain sled that runs with snow on the hood at low speeds.
Click on this thread for my opinion on venting vs ducting on the PRO RMK's.
If you had a vent right next to the inlet of the fan, then yes you would be drawing in cold air and forcing out hot air IMO.
If you did not have a vent next to the inlet (center) of the fan, then you would simply be circulating under hood air and not pressurizing the engine bay(but still moving air past the primary)
I keep my clutches and belts clean and the area around them... sure some will blow around... But since the clutches are the heart of the sled, I keep that area spotless so there would not be a bunch of kevlar and rubber dust to blow around end of the season she gets the motor pulled and everything cleaned back to new (including the injectors)... I like the sled to perform to it's capability and be reliable when I'm places I cant get towed out of with a a Huey on the other end of the line.
At 8200 rpm (clutched rpm), I would imagine That little suckker blows plenty of air. Look at a simple hairdryer and how small the fan is on that thing that is spinning at about 5000 rpm moves plenty of air..
Will it work on a PRO.. or in the Cat for that matter... only one way to find out
BTW.. on that torque link ... who knows...but I think they did use it on their race sleds in the past and stopped when they had the new design.. I believe AC will have it on the new Race sled at Haydays.
https://picasaweb.google.com/lh/photo/e-7cIFvOs9gZw1hWHPlYwA?feat=directlink[/QUOTE]
If you add positive pressure under the hood, does that keep air from coming in the vents?
Could the clutch sheaves use more (any) cooling? For sure. Not quite sold on a teeny centrifugal fan yet. Clever idea though. One thing it will do and that is spread belt dust to previously clean corners underhood, mebbe even on yer new Klim's.....
