Primary Clutch Bolt size?
Murph
Polaris Moderator/ Polaris Ambassador
Polaris Klim
The primary clutch cover bolts are SAE...
What is the primary clutch retaining bolt?? SAE or metric and what size? (80 ft/lbs)
I have the spider nut and spider holding tools. (280 ft/lbs!!!!) Do these need heat to come off? (i.e. loctite green or red???)
Thanks,
Murph
Clutch Bolt Socket size.. in 13/16..
Noramlly heat is not needed..
Some are harder to get off then others.. yes u can use a little heat..
Cutting alum. Pop Can For spacers behind the pucks.. Works Really well and Cheap!!
Hint Hint!
