it doesn't matter what the torque is on a bolt if it breaks, it should spin out easy unless it has loctite or is cross threaded. the bolt doesn't bottom out
Aren't you stress hardening the bolt by doing this, and therefore making it more brittle and more susceptible to a fatigue failure?The main reason I will continue at this spec is ALWAYS after I replace a bolt and torque to 96 ft. lbs. EVERY pre-ride check for the first 3 rides afterwards, I will find the bolt takes just a little more torque each time. Generally after 3-4 checks, the bolt will finally be holding 96 ft. lbs. and will continue holding until the clutch is removed the next time.
Actually, The bolt was new at the beginning of the season... 930 miles is all this bolt could take at the recommended 96 ft-lbs... Maybe it was just a bad bolt, IDK...![]()
I will agree with one question you ask... Would the clutch have stayed on the crank with the bolt only torqued to 80 Ft-lbs?.... I surely don't know, but I am grateful that it stayed on for me.![]()
I apoligize. I didn't read where it had been replaced earlier this year. I remember a couple years ago guys questioning of this increase in torque and wondering if the bolt should be replaced with each clutch removal? Had you removed your clutch any during that time? How about a pic of the washer, maybe sitiing next to a new one.
Certianly this isn't an everyday occurance, don't see it that often. However, we are taking the bolt beyond it's actual design strength so installation with an ACCURATE torque wrench becomes very important. If we install this bolt that's already being torqued beyond it's design, then accuracy becomes even more important. I'm a torque wrench addict. Mine are sent in every year for calibration. I'm not saying that you guys should doo this however, I stress a quality torque wrench and unfortunately the only one I've ever found to be accurate is Snap-On.
I love comparing my co-workers cheaper tw's to mine. I've found many to be off a fresh calibration to ine by 25% and more.
This bolt could've broke for more reasons than we've discussed. I would be curious to see if the clutch galled or slipped on the crank during the ride out.
Another note...I've been finding the washing getting very galled and chewed up from the head of the bolt. With this and it being tapered/concaved, it would be a good idea to replace this along with the bolt.
I've been running a 98 Poo 700 motor for the last 7 years with a broken clutch bolt...just never got around to pulling the threads out and it's held on just fine. Should try running my 900 the same way and just maybe the clutch would finally work it's way off...
I find it hard to believe that Polaris would put in a bolt that cannot take the recommended torque. Where did you get the information it was beyond the bolt's design strength?
