T
TriumphoverU
So I take the primary off of my 700 Fusion to change out the spring and find out that the movable sheave is binding. With the spring removed and the cover off the clutch will close to the point you see in the attached pictures easily. It will close all the rest of the way with some extra force, but is binding pretty bad. After it is forced closed, of course it takes just as much force to open it back up. Any ideas what is causing this?
