powervalves
To check if they are working properly, you can take the cover off the servo motor, pull the clip off, then slip the cables out. Then, pull on each cable. They should snap back quickly and move freely. To adjust, just pull thecable to its max extension and take a measurement. Check in your book to see if it is in spec. If not, adjust the nut on the cable to adjust it accordingly... Hope this helps!
attachment.php
