I just put new gaskets in, and I got a lot of my power back. It stills doesn't idle very well, and it sounds off. The left carb is "spitting" out gas. Not a ton, but it doesn't seem normal.
I put each I the valves in the opposite cylinder, and the good one leaked, and the valve that I thought was bad didn't
Basically with your statement here your say that something on that one side of the motor is wrong Unless i'm miss reading
the low end is horrible, but the high end is good
Now this is completely backwards of what a power valve would do
I say NO WAY Just putting a new gasket under the power valve will give you alot of power back no way. You sir should obviously not be trying to work on a sled as it seems you have no clue as to what your doing THE ONLY WAY THAT EXHAUST IS BLOWING OUT OF THAT HOLE AT IDLE IS A BAD BELLOWS OR BROKEN PART IN THERE. there is nothing else to it. Really it is so straight forward that a cave man could figure it out.TAKE IT TO THE SHOP (SORRY)
Where is it spitting fuel out? Must be a float or needle/seat issue.
So by replacing the gasket for the ves your sled is not leaking exhaust out of the bellows cap hole any more?[/QUOTE
Yes, I don't know how that fixed it, but it did. Now I think I have a stuck float.
