The power valves use cylinder pressure through a hole in the cylinder wall. This hole provides pressure to the bellows and normally vents to atmosphere. The ecu closes the vent using the solenoid at about 5500 rpm. Once the solenoid closes the bellows inflates and opens the power valves. When throttle closes, RPM drops, ECU opens solenoid and vent. The bellows then deflate and the power valves close.
Problem is Polaris only drilled 1/16 pressure holes in the power valve housing and 5/64" hole in the cylinder. These holes gum up easily since they are using combustion products for pressure. Stupid Polaris design! Skidoo has a way better design as they take clean crankcase pressure to inflate the bellows. The fix for Polaris is to drill the holes out in the power valve mount to 5/64" and 7/64" in the cylinders pulse port. Don't hit the piston and make sure to vacuum out all the chips! Clean all parts well, replace bellows and springs. Oil springs well so they don't rust/break. Polaris should have used SS springs. One of mine rusted in half! Next drill 1/2" hole in spot right above left shock tower behind shock upper mount. Route vent hose to this hole and push through snug hole. Leave it sticking out of tub vertical 2". Make sure it is always puffing. With the increased pressure up to the solenoid the valves will react way faster when the solenoid closes. The sluggish valves are the main reason the sleds stumble in the mid range. This is why some sleds do some don't. The pressure ports simply plug up and are slow to open.
Plugging the vent hose does not fix the problem or add performance in any way! Plugging the vent will simply open power valves and keep the open all the time. Low end power will suffer and run poorly.
At minimum take apart and clean the valves and ports.
Someone please make this a sticky!
