I'm still trying to figure out why it's supposedly a good thing to have your skis move around from side to side at random unpredictable times?
Is that part number for a pair?
Or will I need to order two of the listed part number?
When the front suspension moves up and down, the horizontal distance between the skis changes. Or another way to think about it -- When looking head-on at the sled and moving the suspension, the spindles travel in arcs instead of perfectly straight up and down. This suspension movement creates camber gain.
Breaking down the motion of the camber gain suspension arc (vector mechanics), the majority is vertical motion with a minor horizontal (sideways) component.
Click for animation >>>
http://www.miracerros.com/mustang/t_animate_sla.gif
In a vehicle with tires, like the animation above, as the suspension moves up and down, the tires are actually scrubbing sideways on the road. With a snowmobile, we've got a skis with deep keels, topped-off (or bottomed-off
) with steel bars laced with a carbide. Skis are definitely not something that something that likes to go sideways -- It's against their reason for being.
On hard packed snow or an icy trail, the carbides and skis are going to "dig in" and resist moving sideways as the suspension tries to move up and down. Since the ski/carbide can't move horizontally, the front suspension essentially binds up in the vertical direction as well. This suspension binding makes for a pogo stick, jerky response from the front of the snowmobile.
The Sno Pro ski springs allow the skis/carbides to remain dug-in and frees up the spindle motion allowing it to slide horizontally on the ski bolt. Since the spindle is now freed up to move side-to-side, the vertical suspension motion we need is now more comfortable, capable and tuneable.
On a M, lift up the front of the sled and take the two spacers out of your skis. Put the skis and ski bolts back in without the spacers and drop the sled to the ground. Bounce the front of the sled up and down and watch the interaction between the vertical spindle and the horizontal ski bolt. After that little experiment, the Sno Pro springs will make perfect sense for those who have to see to believe.
Another advantage I've found with the ski springs is they provide a little more side-to-side forgiveness when bouncing off trees. The ski will hit the tree first, the sled's momentum will collapse the spring, absorbing the impact, albeit to a very small degree.
The Sno Pro ski springs also automatically push the skis out to their widest track width when cruising straight along providing better stability. As soon as you tip the sled up on its side for carving or sidehilling, the spring collapses allowing the ski to tuck in to the narrow track setting. Wide ski spacing when you need it and narrow when you don't want it. The best of both worlds.
In summary, the Sno Pro springs improve front suspension response and provide for automatic ski width adjustment.
No Holiday Express here.
