First off, NONE of the parts on your sled (with the exception of the epoxy bonded joints) will ever get hot enough to change any of the tempering of the steel, anyone who tells you otherwise is just plain wrong.
As for the spindles, I chose to anodize as the alloy used takes the process very well. And you don't have to deal with the clearance issues that powder coating causes, and with powder coating there is not physical way to insert the part into the area without damaging the finish outside of where the surfaces will be joined.
I powdered my arms and anodized the spindles and the finishes turned out surprisingly similar. wouldn't change a thing about the setup.
