I'll be the Debbie Downer.
I think highly of Brad's products and knowledge but I found the head didn't give me as much as I got from a head on my CFI4. I had to run my ethanol fuel plug at 9K+ to keep the det sensor from coming on. So I was losing a little power by doing that. It seemed that I was better off running my sled with the stock head and non-ethanol plug. Now those with non-ethanol fuel might really enjoy this head. Or you can mix in some race/av fuel which I also tried. Just don't plan to make huge gains. You get better throttle response and a nice kick in the mid range. Brad's power curve shows that there is almost nothing on the top.
I run them and sell lots of them...highly recommended. More power, higher DET threshold, better cooling of the hot spot around the exhaust side. Win/win
I won't trade my 4 year warranty for 10 HP, I don't even want to put a can on my new 13. Poo is poopy about warranty.
How do you get higher det threshold with more compression? I typically see BugIto's results more often than not with most aftermarket heads tho there are a few that are much more efficient and can make up for some of that.
Also there are two versions - the cheater head where I'd argue you won't see better cooling and det is a concern; and then there is the billet head with much larger cooling capacity where I might agree with that claim. Having stated all this, I'm guessing it's worth the extra $100 for the billet head - correct me if I'm wrong.
Finally, most are reporting a need to go 2 grams heavier with clutch weights using these heads. If there's no HP gain up top then there surely is some torque gain and you're still benefiting. Again, correct me if I'm wrong.
Have FUN!
G MAN
The reason I bet u were det'ing was u were over tacking with the additional power. The pro is very sensitive to this and if u are already close to the threshold and add more power, u will over tack out of the hole or in mid range power. Throw more weight at it and I bet no more det light.
