Potential problem on your gen 5 check this for wear
If your running stock muffler with the sound / heat shield check for wear on the coolant hose I’ve seen some rub the hose almost through in under 1000 kms this sled only has 600 kms . On my own sled I’ve wrapped the hose with a old bar grip and zip tied it in place
this has been brought up before on the forum but there’s likely more than one spot. I use clear racers/ helicopter tape.
No longer an issue on the 24’s but definitely the 23’s
My hoses were replaced under warranty because of that rubbing.
mine is at the dealer for the chain and fuel line recalls, they are changing the rad hose as it is worn pretty good in 1100km
my dealer said they have been pulling out the inside heat fiber heat shield and tossing them away
I haven't been contacted for any recalls, do you know if it's all 23 summits?
call your dealer and run the VIN and know for sure. I’ve got a low mileage 23 turbo and they replaced the fuel line. they said there was enough wear to replace as opposed to just rerouting or whatever they do.
