How did this hold up? Have a few lugs I need to repair. ThanksWe tired the loctite 404. its just cracked. too brittle We fixed about 6-7 splits like this
We did the repair this summer haven't tried it out yet. We used E6000 and 3K plain weave Carbon fibre cloth fabric(amazon) did a coating of the E6000 set the finer cloth into it and re coat over top to saturate the cloth.
Figured the E6000 needed some support
View attachment 396390View attachment 396391View attachment 396392
Will let you know hot it holds up
What glue is this gorilla glue? I looked and nothing says impact?Gorilla glue impact works better than Loctite 404 in split lugs
What track is that? Has the camso lightweight track clips?!?!I use ECRF cold bond to repair tracks. When I get a tear I use Kevlar string and stitch for strength then coat with a couple layers of the ECRF. Works really good.
I check my track after each ride and make repairs to ripped lugs as necessary.
View attachment 396393 View attachment 396394 View attachment 396395 View attachment 396396
Any pictures of the repair? I used E6000, cleaned surfaces, cured several days with heater under tunnel and tarp over it, first ride out and it failed completely. Vertical split in a lug, partial, and a crack down lower... Loctite 404 with primer is what I have heard works best...E6000 works great.. still holding after 7 days in deep snow
