Awesome build man.
Few questions:
Don't your knees hit the handlebars with the seat at that angle?
What are you trying to accomplish with the sled? Lighter? More power? Reliable until you can walk into Howie's and 'check a new one?
What kinda riding you do? Do you hang out with Bryce and Ryley and those boys with turbo's and all the pimp sht?
Few tips if you want to go further with the build:
Forward mount the steering post. But if you ride hard, you'll want a new post. Wildchild or CR Racing both offer kits. I used a Wahl bearing mout and CR's offset post. Totally new sled.
Front suspension - 1M front end off a '03+ will net you big weight savings, along with more travel and newer spindles and housings. Steering arms will need to be cut and tapped to fit.
Rear skid - pretty much anything '06 + will net you a good 15-20lb savings. You don't need anything expensive like a Kmod or Timber. Just a solid stock skid from any Pol, Cat, Doo that came stock in the last 5 years. Some are better than others, I prefer Pol('08+) and Cat('09+) but find out what you want to spend on something for the weight savings. Spacers or longer axles will be needed because your tunnel is wider.
Hood - BR Tech makes a wickedly light hood, I'm sure with all the Cat boys in PG someone has a lightweight hood they got kickin around the shop somewhere. If not, I do have a fiberglass mold and I pop a few out as I need them.
Power - twin pipes and '94-95 electrical system(stator, cdi, etc etc) and a simple blueprint of the motor(cylinder to case ports can use a lot of work to flow properly). Shave the intake boots to move the carbs closer to the motor(helps responsiveness).
I also swear by UFO's for this motor. Smooths out fuel delivery and helps with throttle response again.
I had 10,000 Miles on my bottom end before it let loose. I did open it up when I installed the 790 kit and had the entire motor balanced. Made a huge difference in engine life, not to mention clutch life and the smoothness of the entire sled.
Recap:
Front and rear skids can be bought used and for great deals considering you're drastically dropping weight both front and rear.
Hood saves mucho weight as well. I run a LeadDog light and chucked the heavy stock light.
Nice project man, keep us updated and if you need any help, let us know. Few of us have done this a few times......
Few questions:
Recap:
