What should the compression be on stock 11 pro? Mine tested out at 105 in each cylinder. Thanks
Elevation also has an effect on compression fyi.
Warm motor, throttle wide open
I could only get 90 on mine and the ladies 800's in littleton but each tester will read different.
How many miles you have on yours sledsnoco?
We both have 1300 and I'm putting Rk Tek kits in both before they roll again
I hope his kit works out better for you then some of ours did in the past. If not we will be able to tow you you home!!
My Pro has 1200 miles on it since I put rktek replacement wossner pistons in it. Cold I get 105 in each side, warm I get 110 in each side. Wossner pistons seem far superior than anything else I've ever used.
Great post! Maybe if your screen name wasn't jDOG I'd take you seriously and ask about your experience
