So for only $8-900 I can add a gps to my sled?
Why does this not seem like a good deal?
Does it even work with pull start sleds? Gotta add a battery or only use it with the sled running?
Its a bit pricey but I got mine through snowcheck. Didn't really cost much more then. Problem for you guys in the mountains is you do need a battery to use it to full potential. You don't need one to use it but every time you shut sled off it will power down and loose satellite signal. Once the machine is started up it will boot back up. The other issue is reverse. Every time you reverse the gauge will shut down and boot up, same for switching back to forward. Might get a bit annoying.
All snowchecked sleds that came with the IDD came with a battery whether or not they had electric start. One nice thing is I can power up the gauge without starting the sled. This allows me to update and trip plan without the sled running. Perhaps Polaris will have some sort of lightweight mini battery for RMK's next year. There is a tonne of info over on HCS in the AXYS platform board. Even a sticky on it.
