CDK I was experiencing a few issues myself after putting together a RK Tek big bore. Sled ran well for a good 300 + miles. Slowly my sled started having a stumble on high end. I tried endless acts of replacing and checking parts. I put the sled back to 100% stock and it continued to cut out with random misfiring on top end. That's when I really started thinking my issues leaned more towards electrical not a fueling issues.
I dug into my owners manual and looked up what all the sleds sensors should read for ohms.
With a good volt meter I was able to determine the stator had very high readings on one side. I then followed the diagram to see what was all effected by this. The stator which provided power to my fuel pump, coils, and numerous other components was receiving unstable and changing currents causing my engine to miss fire.
So after reading you post. I truly believe if you find a manual or get those values from your dealer. Take the time to ohm out your system you'll more then likely find which component is the problem child.
Good luck...
Good luck...
