C
CDK
I have a very weird issue, sled will no longer start and I cannot diagnose it. I'm hoping one of you has seen my symptoms before. Please, no brand/part/ manufacterer bashing, pretty sure it's all been said before.
I was running my sled Fri night, and it was running great. It's a custom turbo project that I've put together, and I finally had it tuned and working. I parked it after running it in the field, light-moderate load on the engine, nothing crazy. Saturday, I fired it up, let it idle for 30 seconds, then switch to reverse and backed out of the shop. Hit the button to go back forward, and it died. Hasn't ran since.
Here's my setup, and bear in mind it was working damn near perfect when I parked it:
-2012 Switchback Assault
-RK Tek 858 Rev 1 kit, 12.5-1 cheater head
-Stock Pipe
-Boyseen Turbo Reeds, brand new
-Vipec ECU
-2012 Silber Turbo, downpipe, oil tank
-2013 Silber silicone charge tube, billet adapter with secondary injectors
-Turbo performance wiring harness with Map sensor, IAT sensor
-Factory Map used for BAP, tied to overstructure
-CPC rising 1-1 fuel pressure reg, set to 60 psi
I've torn into everything I can think of, trying to figure out why it won't fire again.
-Compression is 120 psi across both sides
-Spark plugs are good, pulled and grounded them to head bolt to visually confirm sparking
-Injectors are good, pulled the whole fuel rail and bench tested them to witness both spraying properly
-Motor has good vacuum, as tested by covering my intake pipe with the palm of my hand
-Vipec appears to be functioning propery. Logged in and tested injectors, fuel pump, kill switch, cold start maps, etc.
-If I spray fuel in the spark plug holes, it WILL fire for a few stokes, then die. This makes me think it's a fuel issue
I'm at a loss guys. The only thing I can think of is the injectors are not being told to fire during startup. Any thoughts??
-Stock Pipe
-Vipec ECU
