Polaris 800 Big Block VES motor *****SOLD*****
This is a Polaris 800 Big Block VES motor Newly Reconditioned by myself @ SLP from the crank and case up. I built this motor with the intention of drag racing it so I put extra time into details. Unfortunatly the race plans fell through (new baby) so the motor has to go. The case was stripped and line bored back to the factory tolerance of .0015” crush. The crank has a SLP billet PTO end and all new bearings as well as the SLP double row PTO bearing tough boy kit and the run out measures .00025” and under. The cylinders Have new nikasil and were ported by SLP. I hand match ported the flow lines from the case to the cylinder as well as the exhaust port to the flange so the entire motor has been match ported. The exhaust valves have been matched to the exhaust port as well. It has SLP power dome heads to run pump gas from 6000 foot and higher with a single pipe. I can also install different domes if needs be. Motor includes recoil, stator and flywheel. $1995
