More fine details on updates:
POLARIS 2025 QUALITY IMPROVEMENTS
Polaris engineers addressed several areas of quality improvement focus for model year 2025.
POWERTRAIN UPDATES
P22 Improvements
* Forged spider
* Improved cover
* New clutch bolt
650 and 850 Piston
* Improved durability
* Improved heat transfer
850 Patriot Oil System
* Increased low RPM oiling for improved durability
Patriot Boost Aux Injector Harness
* New and improved fuel injector wiring design and material
Patriot Boost Turbo Seal
* Improved sealing and reliability
New Spark Plugs
* BPR8ES spark plugs for 2025
PTO Rear Engine Mount
* New 2-bolt rear mount bracket
CHASSIS UPDATES
New Starter and Bendix
* Greatly improved starting reliability and performance
Dual Extrovert Drivers
* Standard now on Patriot 9R and Boost Switchback Assault
RMK Rear Bumper
* Stronger
* Increased durability
* Maintains proper failure mode
Oil Bottle
* New mesh in oil bottle screen to reduce air bubble occurence
New Rail Caps
* Standard on all RMK models
Recoil Rope Guide
* New and improved recoil rope guide
* Improved wear resistance
7S DISPLAY UPDATES
Wifi is back
* Removed in model year 2022, back for 2025.
* Easily transfer and update data from the app.
New 5-way Switch
* Massive durability upgrade
Quality Improvements
* Key user improvements such as fuel readings and maps crashing.
New Ride Command features coming on 2025 7S
* Open Ride Areas
* Heat Mapping (shows where other riders have tracked recent rides
Other updates
*Up to 7lbs lighter
*1” Lower lightweight seat (9R & Boost)
*New throttle system
*New running board/Suspension mounting pad
*New lightweight LED headlight
*Lighter and stronger driveshaft
![changes.jpeg changes.jpeg](https://www.snowest.com/forum/data/attachments/361/361824-4e129506c4639c0c5874ffd4a60c4385.jpg)
POWERTRAIN UPDATES
P22 Improvements
* Forged spider
* Improved cover
* New clutch bolt
650 and 850 Piston
New Spark Plugs
CHASSIS UPDATES
RMK Rear Bumper
* Stronger
Oil Bottle
New Rail Caps
Recoil Rope Guide
7S DISPLAY UPDATES
Wifi is back
New 5-way Switch
* Open Ride Areas
Other updates
*Up to 7lbs lighter
![throttle.jpeg throttle.jpeg](https://www.snowest.com/forum/data/attachments/361/361822-1016bb6213230ff932d2a87ebd576548.jpg)
![tips.jpeg tips.jpeg](https://www.snowest.com/forum/data/attachments/361/361823-77d6a17a35b7dd17e59e2759aedb104f.jpg)
