so here is the lowdown. i blew the crank on my 07 800R 151. 1 month later the backordered engine showed up and was installed. After 4 rides about 50-60 miles each i figured that the motor had been broken in and ready to really ride hard. before the 5th ride i had the SLP powerdome head installed and went for a ride the day i picked it up. not even fifteen miles into the ride the left piston detinated. i only put Chevron fuel in my sled and am totally anal about only using 91 octain or higher.
if you have any suggestions on what could have caused this problem i would be greatfull. as of today they have replaced the piston and the damaged Dome and i am told the problem is fixed. my fear is that nothing has really changed and the very next ride i go on i might have the same problem, or is this just my bad luck and a total fluke or bad piston. so far i have been towed out of the backcountry 3 times. twice with a blown motor and once with a blown chaincase. i really really do not want to get towed out or walk out again this winter. thanks in advance for any help or advice.
