play in apex steering
These are my new ones I make , its a diffrent plastic that is better self lubricating properties.
The bushings also have more surface area than the stockers and greasable.
I also changed the design so they use the stock spacer collars so they can not be over tightened.
billet yam blocks 017.jpg billet yam blocks 030.jpg billet yam blocks 008.jpg
So these kits are to tighten up the steering correct? I have an Apex RTX that has about an 1 1/2" of play at the end of the bars and I am looking to fix that over summer. I don't know much about how the steering system works, but what does this kit exactly do? Does it replace just the stock bushings or does it do more than that? Will it keep the steering tighter for longer? Where exactly does the steering slop come from?
I am very interested in this kit, just want to make sure it will solve my problem before I buy it.
These blocks replace the factory steering blocks, Some of the original blocks I built have two and half years on the same bushings with no slop.
You might want to watch your steering and see were your excess movment is. It could be a heim end , a arm bushing, spindle or the factory steering bushings.
Theres lot of moving parts to watch for.
We will have a 6061 T-6 billet version of this part available within the next couple of weeks. The bearing surface is "super oilite" - oil impregnated bronze - that does not require lubrication.
The parts will look something like the following picture, and will fit Apex (3 req'd), Nytro MTX (2 Req'd), and the Phazer MTX (1 Req'd).
